gido
is the output common-mode voltage of a single -ended op-Amp the same as the offset? if so , then that's what i mean......i got an output offset voltage of -5 mV without any input signal. With a sin wave input, and running the transient, i still get a voltage of -5mV at the output but with a square wave input,i get an output voltage of -397mV.. thanks...
