sandman
This is more of an issue with the tool itself than the simulation (I suppose)..
I notice that when I run a pnoise (together with a swept pss) and choose the pnoise_separation from the <direct plot>, the window always seems to become distorted.
Pnoise_separation gives me the noise transferred from each circuit component, at the output. As an alternative, I've tried using the results browser to access the same data, but the tool starts to hang when I access the pnoise_xfersrcs_sweep data.
Has anyone had a similar issue ? It would be nice if you have faced this and have a solution to share !
cheers,
