Hannibal
Frank Wiedmann wrote on Feb 15th, 2012, 6:00am:Hannibal wrote on Feb 15th, 2012, 5:37am: based on your post, I will have only the injection signal in PSS simulation !! Sorry, I don't understand your problem. The output of your oscillator, which you want to examine, is not identical to the injection signal, is it? That's it !! I tried your configurantion (PSS with only the injection signal) but currently I have convergence problem !! Does anyone know the difference between shooting method and harmonic balance in PSS simulation ? Is that the shooting method is more accurate than harmonic balance ? Thanks, Hannibal
