Jul 30th, 2024, 1:15am
Pages: 1 2
problem with small capacitor in layout (Read 3956 times)
nus_lin
Feb 23rd, 2012, 8:47pm
dear guys,
i have a similar problem in using a small capacitor in layout. The minimum MOM capacitor offered by the design kit is around 15ˣ15um2,which is much larger than what we want. Therefore, if my unit capacitor is smaller than that value, I am not able to pass the LVS check, and can not run the post-layout simulation either.
can anyone advise me how to get this done?
thank you in advance.
regards,
HE LIN
yvkrishna
Re: problem with small capacitor in layout
Reply #1 - Feb 23rd, 2012, 11:44pm
hi HE LIN,
I understand that the minimum cap value realizable as per layout guidelines is  higher that what you need in the design.
What is the order of cap value you are looking for ? if it too small the adjacent parasitic cap can simply dominate it.
And you can use caps in series , or a combination of series and parallel caps to get to the value you wanted.
yvkrishna
raja.cedt
Reply #2 - Feb 24th, 2012, 2:30am
Why don't you make MIM caps by yourself in top metal?? It offers less capacitance based on your requirements. people go for MOM cap only if they need big capacitors but in your case it is different. If you want to go with PDk caps as vamsi suggested go with series combinations of big capacitors, in fact this is a good option if you need less mismatch as well..
Enjoy
Reply #3 - Feb 24th, 2012, 2:13pm
what value of C are you looking for?
what is the value of parasitic C presented to substrate by the metal interconnect
at the node of interest?
if those two values are anywhere near each other you need to redesign your circuit to use a larger C.
nus_lin
Reply #4 - Feb 24th, 2012, 7:11pm
thank you, vamshikrishna, raja.cedt, and loose-electron
actually i am already using c-2c architecture to reduce the effective capacitance.
the process i am using is 65nm, where mim cap is impossible. the only choice is mom cap. the unit capacitor i am trying to implement is 8fF, which should be much less than parasitics.
the ninimum mom cap in design kit uses 25 fingers, and is 32fF. so i am quite sure, if there is a way to adjust the minimum finger requirement so that i can use 9fingers, then things will become quite easy.
problem is how?
yvkrishna wrote on Feb 23rd, 2012, 11:44pm:
hi HE LIN,
yvkrishna
RobG
Bozeman, MT
Reply #5 - Feb 25th, 2012, 8:50am
You can build a cap with nine fingers if you like, but you will have to waive the DRC rule violation which is a matter of company policy, not physics (bear in mind the 9 finger cap isn't going to be as accurate as the 25 fF cap - watch parasitics). You need to be talking with your supervisor and process guys about this to see if they will let you build a cap that small since it will violate the rules.
At ISSCC this year someone had a 0.6 fF cap in their design.
nus_lin wrote on Feb 24th, 2012, 7:11pm:
problem is how?
hi HE LIN,
yvkrishna
Reply #6 - Feb 25th, 2012, 12:46pm
"At ISSCC this year someone had a 0.6 fF cap in their design."
Yeah, and I have seen a lot of other stupid stuff in papers and presentations.
Things like that get lost in the process variance, or got added to tweak
a simulation, and don't have a lot to do with what happens on silicon.
I remember a S&H circuit where it was really small hold
capacitor, and when I asked the designer about the input capacitance
of the transistor connected to it, they drew a blank.
Turns out the input capacitiance of the next transistor was
about 50X bigger than the "hold" capacitor.
Reply #7 - Feb 25th, 2012, 12:49pm
a controlling capacitor in a circuit should be much larger than the parasitics
at the node. Not smaller.
You want your explicitly defined device to be the primary control
not the parasitics.
nus_lin
Reply #8 - Feb 27th, 2012, 1:06am
sorry, by less i actually mean bigger.
loose-electron wrote on Feb 25th, 2012, 12:49pm:
not the parasitics.
Lex
Eindhoven, Holland
Reply #9 - Feb 27th, 2012, 4:39am
You could try widening the spacings of the MOM and then verify the capacitance with the extraction tool. Since at that point you are making your own device, you are then dependent on the accuracy of your parasitic extractor (not without risk).
RobG
Bozeman, MT
Reply #10 - Feb 27th, 2012, 5:56am
loose-electron wrote on Feb 25th, 2012, 12:46pm:
It was in a cap DAC for a SAR. Caps in the few fF range are becoming more common.
boe
Reply #11 - Feb 27th, 2012, 7:04am
RobG wrote on Feb 27th, 2012, 5:56am:
My tuppence worth: As long as you know what you are doing, fine. Otherwise, a recipe for disaster.
- B O E
Reply #12 - Feb 27th, 2012, 2:24pm
Yeah, and KT/C noise hasn't changed last I checked.
Lex
Eindhoven, Holland
Reply #13 - Feb 28th, 2012, 3:58am
Hahahah =D
Good point!
Just out of curiosity, could you pass the link to that paper?
RobG
Bozeman, MT
Reply #14 - Feb 28th, 2012, 7:55am
Lex wrote on Feb 28th, 2012, 3:58am:
Hahahah =D
Good point!
Lex - the paper was 27.8 by Pieter Harpe, but you won't find much information there. However, last year he had a JSSC paper that talked about building a 0.5 fF capacitor with 90nm CMOS. It is here: http://ens.ewi.tudelft.nl/pubs/meijs11jssc.pdf
It seems to have some good information in it.
kT/C noise isn't much of an issue since the signal is sampled onto the entire DAC, not just the LSB cap.
rg
Pages: 1 2
