Jul 17th, 2024, 7:37am
The analysis of RLC in series is inconsistent with simulation results. (Read 2460 times)
xxgeneral
Feb 24th, 2012, 12:56am
Hi everyone,
I simulated a simple circuit with RLC in series under Cadence Spectre. L and C resonate at 1MHz. A sinasoidal source with an amplitude of 600mV stimulates RLC at 1MHz. And, R=50Ohm, L=25.33mH, C=1pF.
My thought is, LC gets its minimum impedance at 1MHz. So in steady responses LC has a very low voltage, wheras R has a large one reaching 600mV.
However, the simulation result is reverse. That is, LC has a very large voltage, nearly 600mV. R has a small one, only 20mV.
I did another simulation with L=25.33uH and C=1nF. Then,  LC has a very low voltage, and R has a large one reaching 600mV.
This confuses me a lot.
Anyone can help me?
Thanks a lot!
raja.cedt
Re: The analysis of RLC in series is inconsistent with simulation results.
Reply #1 - Feb 24th, 2012, 2:20am
hello,
be clear when you are saying some thing. Even though resonance frequency is same in both cases Quality factor is different, so the final voltage across the inductor and capacitor is equal for any circuit and it is equal to Q*Vin and voltage  across resister resister will be Vin.
case 1: (L=25.33uH and C=1nF): So here Q will be around 3.1, so volate across inductor and capacitor will be 3.1*600mv=1.8v, this is the value even i got through sim.
case2: (L=25.33mH, C=1pF): here Q=3183, so voltage across L and C wil be Q*vin.
But one thing may be you have to run sim for more time, because in the second case Q is very high so it takes time to reach steady state.
Raj.
Reply #2 - Feb 24th, 2012, 2:02pm
raja.cedt wrote on Feb 24th, 2012, 2:20am:
hello,
Raj.
Agreed!
and also is this AC or TRAN simulations?
xxgeneral
Reply #3 - Feb 25th, 2012, 5:01am
hello,
Raj.
Hi Raj.
Thanks for your help.
