Apr 29th, 2024, 6:33pm
SpectreVerilog: "reset" signal stays in "stx" (Read 2441 times)
ahhfyz
Feb 24th, 2012, 11:05pm
Hi, everyone!
I am simulating a mixed signal system using SpectreVerilog. In digital part, there is a "reset" pulse signal, whose width is 100ns. However, it stays in "stx", therefore the digital circuits cannot be reset, and simulation result is no sense.  How could this happen? Thank you!
boe
Re: SpectreVerilog: "reset" signal stays in "stx"
Reply #1 - Feb 27th, 2012, 6:37am
Hi Ahhfyz,
It is difficult to give you a concrete answer with so little information:
Which tool version do you use? Where does the reset come from? What IEs do you use? Do you simulate power-up phase? Waveforms?
- B O E
