Sep 11th, 2024, 6:17pm
MFB high-pass Filter not having a unity gain (Read 2314 times)
gido
Feb 25th, 2012, 9:41am
hello,
I am designing a high-pass filter using the multiple feedback configuration. I am doing the AC analysis and i have tried several times but it is not giving me a unity gain (1000mV). my input voltage is 1V.
I have changed op-Amp design but still no nice result.
Can anyone help me here?
I am running cadence.
rfidea
Europe
Re: MFB high-pass Filter not having a unity gain
Reply #1 - Feb 25th, 2012, 10:21am
The gain of a MFB filter is set by a resistor ratio. Please look at page 7 in the following document.
http://www.ti.com/lit/an/sloa049b/sloa049b.pdf
As a general recommendation I think you should start the filter design with an ideal opamp, use an inverting amplifier with a lot of gain. Then you will see if you have a fundamental problem with your RC networks or not. Get that to work first. It it then do not work with a real opamp, the problem is related to the opamp.
buddypoor
Bremen, Germany
Reply #2 - Feb 26th, 2012, 9:44am
gido wrote on Feb 25th, 2012, 9:41am:
hello,
I suppose it shouldn't be a problem to give you some hints - but without any circuit information? What do you expect?
