Sep 17th, 2024, 11:14pm
Pages: 1 2
Passive filter Implementation (Read 614 times)
gido
Feb 27th, 2012, 1:51am
I am designing a high-pass filter for a cut off frequency of 0.05 Hz. I would like to know if it would be ok to use a passive filter implementation....
raja.cedt
Re: Passive filter Implementation
Reply #1 - Feb 27th, 2012, 2:40am
hello,
it's up to you, 0.05 cutoff frequency means large area!!!, so i would suggest active.
Lex
Eindhoven, Holland
Reply #2 - Feb 27th, 2012, 4:00am
Or digital?
gido
Reply #3 - Feb 27th, 2012, 5:04am
ok. But i was thinking of switched capacitor implementation of resistors which would probably obviate the large resistors hence large area.
Would that be advisable if the high pass filter is to be used in a SOC ECG .
An instrumentation amp comes before the HPF and a VGA comes after it.
Thank you.
Reply #4 - Feb 27th, 2012, 2:17pm
Why not a control feedback system to get rid of the DC?
gido
Reply #5 - Feb 28th, 2012, 12:10am
ok .  Loose-electron, please can u suggest some good links where i can find the control feedback stuff? I am not conversant with it,.
Thanks.
Reply #6 - Feb 28th, 2012, 6:22pm
Detect the DC content (a LPF)
use a summation circuit to subtract that value from the
signal.
Essentially a control systems problem.
Vladislav D
The Netherlands
Reply #7 - Feb 29th, 2012, 4:15am
loose-electron wrote on Feb 27th, 2012, 2:17pm:
Jerry, you mean chopping, don't u?
raja.cedt
Reply #8 - Feb 29th, 2012, 4:22am
no..i guess what he mean is Auto zeroing, or ultimately you are using 1-Z^-1.
Raj.
aaron_do
Reply #9 - Feb 29th, 2012, 5:00am
Hi Loose_electron,
signal.
does this kind of implementation not still suffer from the same issue of large size? I'm thinking the LPF corner frequency needs to be very low
cheers,
Aaron
RobG
Bozeman, MT
Reply #10 - Feb 29th, 2012, 7:21am
raja.cedt wrote on Feb 29th, 2012, 4:22am:
You can do it continuous time -- we used to call them servo loops -- basically a low pass filter in the feedback in a loop. But then I believe you still have the problem of generating a low freq pole. For 0.05 Hz, using a 10 pF cap you need to synthesize a 318 G-ohm resistor. A simple gm/c filter would use about 1 pA of current so that won't work! I'm not sure if a simple switched cap would work - I thought you needed an opamp to make those work very well.
It seems to me that the area of an opamp is going to be small compared to the capacitances that you need.
Like Raj, I was also thinking some double sampling method that would give you a (1-z^-1) transfer would be the easiest (i.e. sample twice, subtract the result). In practice this could be done by sampling the input and then subtracting the sampled value from the continuous time input before the amplification (which is essentially what Jerry is suggesting but without an explicit feedback circuit).
I've never done this, but one simple thing that comes to mind is to AC couple the signal into the IA. Periodically "zero" the input of the IA by shorting the IA inputs to a reference. This will sample the input voltage on the AC coupling caps. Then, when you open the shorting switches, the IA will be amplifying the difference, giving you the (1-z^-1) characteristic. The roll-off will be determined by the sampling rate, not the cap. However, the caps will need to be big so that leakage doesn't drain them since your sample time will be longer than 20 seconds.
Seems tough. If common mode leakage currents don't kill you, mismatches in leakage currents probably will. It is better to do it in the digital domain if you can (and also remove the low freq effects of the IA)...
Let us know what works for you.
rg
gido
Reply #11 - Feb 29th, 2012, 7:28am
ok. Thanks all. The timeline is close enough . I think i have to employ the Gm-C with special techniques to realise the low Gm needed.....
Any suggestion?
Vladislav D
The Netherlands
Reply #12 - Feb 29th, 2012, 8:46am
gido wrote on Feb 29th, 2012, 7:28am:
Any suggestion?
High-pass RL filter with active inductor (two gm elements and 1 cap). The values of components should be quite decent. Of course, it depends on the bandwidth you need...
Vladislav D
The Netherlands
Reply #13 - Feb 29th, 2012, 9:09am
not so decent...miscalculated it....
RobG
Bozeman, MT
Reply #14 - Feb 29th, 2012, 9:36am
Vladislav D wrote on Feb 29th, 2012, 9:09am:
Curious what numbers you came up with... Are active filters regularly built with this low of cut-off?
I'm starting to think a dac in a feedback loop to zero the input periodically... Convert the residue and add it to the feedback dac and you'll have the entire signal digitized (or just look at the residue value if you just want the high frequency portion).
Pages: 1 2
