Quote:Curious what numbers you came up with...
Considering first order LR with tau at L/R and the desired tau 20sec, even with a resistor 10 Ohms, L should be 200H. If a gyrator has inductance L=C/gm^2, and let's suppose minimum gm value is 5uA/V, C should be 5nF...heh
