Jul 17th, 2024, 6:26pm
Cross statements and simulation speed (Read 2152 times)
Bob Atwell
Tucson, AZ
Feb 28th, 2012, 12:39pm
OK I am confused.  (Not an unusual condition.)
Based on what I thought I knew, Version 2 below shoud run slightly faster than Version 1 since the assignment statements occur within the cross statement.  However this seems not to be true and in my test case it actually runs very slightly slower.  Can someone explain?
Thanks,  Bob.
Version 1:
  @(cross(V(s) - 0.5))
  if (V(s) < 0.5)
        y1 = 0;
  else
        y1 = 1;
  V(q1) <+ transition( y1, td, tt );
Version 2:
  @(cross(V(s) - 0.5, +1))
     y1 = 1;
  @(cross(V(s) - 0.5, -1))
     y1 = 0;
Frank Wiedmann
Munich, Germany
Re: Cross statements and simulation speed
Reply #1 - Feb 29th, 2012, 12:53am
I guess that version 2 does two separate tests for a cross event at every timestep whereas version 1 only does one test. The test for the cross event might take considerably longer than the if statement because values from two different points in time are involved. In version 1, why don't you trigger the if statement with the cross event?
Bob Atwell
Tucson, AZ
Reply #2 - Feb 29th, 2012, 5:42am
Thanks, that makes sense.  The real model I was working on  is a bit more complicated than this example but I think I can streamline it some.
Thanks again.
