Jul 17th, 2024, 8:32pm
Need help with Arithmetic & Logic Unit (Read 1320 times)
tomaul1
Mar 05th, 2012, 3:51pm
Hello, let's say I have this module:
module ALU(      input      carryIn      ,
           input      [2:0]      func            ,
           input      [31:0]      left, right      ,
           output reg            carryOut      ,
           output reg      [31:0] out );
always @(left or right or func or carryIn)
case (func)
3'b000: {carryOut, out} = left + right + carryIn;     //add
3'b001: {carryOut, out} = left - right – carryIn;      //sub
3'b010: {carryOut, out} = {1'b0, left & right};        //and
3'b011: {carryOut, out} = {1'b0, left | right};        //or
3'b100: {carryOut, out} = {1'b0, left ^ right};        //xor
3'b101: {carryOut, out} = {1'b0, ~left};                //not
3'b110: {carryOut, out} = {1'b0, left};                      //left
3'b111: {carryOut, out} = {1'b0, right >> 1} ;       //shr
endcase
and the following module that incorporates the ALU:
module alu_acc( output reg [31:0] acc_reg ,
                        input [31:0] in ,
                        input [2:0] func ,
                        input cin ,
                        output cout ,
                        input clock );
                wire [31:0] out;
ALU alu(.out (out) ,
           .carryOut (cout) ,
           .carryIn (cin) ,
           .left (in) ,
           .right (acc_reg) ,
           .func (func) );
always @(posedge clock) acc_reg = out;
At every positive edge of the clock, we apply {func,cin,in}={..}, so if we apply:
{func, in, cin} = {3'b000, 31'b101, 1'bx} // acc_reg = 31'b101
{func, in, cin} = {3'b010, 31'b010, 1'b0} // acc_reg = acc_reg + 31'b10 + 0
{func, in, cin} = {3'b011, 31'b011, 1'b1} // acc_reg = acc_reg - 31'b11 - 1
then we get acc_reg=31'b011.
I am asked to modify the ALU module in order to make the same operations to a string of numbers, in which the negative numbers are represented in 2's complement. I can't figure out what to modify, where to modify or anything else...
Please help me with this, I am just starting to learn verilog and Digital Integrated Circuits, so I am limited to ideas for solving this.
Thank you very much!
