Aug 15th, 2024, 10:20am
Inversion level factor (Read 1917 times)
gido
Feb 29th, 2012, 1:01pm
Hello gurus here,
Can someone explain to me what is meant by Inversion level factor(IF) and the formula for it?\
thanks!!!
Re: Inversion level factor
Reply #1 - Feb 29th, 2012, 2:14pm
care to better explain the context of the question?
Dan Clement
Salt Lake City, Utah, USA
Reply #2 - Feb 29th, 2012, 6:00pm
In weak inversion for mos devices it's the ratio of drain current to saturation current. If equal you are in moderate inversion. Greater than ten strong inversion. Less than than ten weak inversion.
Saturation current is process dependent.
Normally I have heard this ratio called inversion coefficient not factor but I think it means the same thing.
