Dan Clement
Salt Lake City, Utah, USA
In weak inversion for mos devices it's the ratio of drain current to saturation current. If equal you are in moderate inversion. Greater than ten strong inversion. Less than than ten weak inversion.
Saturation current is process dependent.
Normally I have heard this ratio called inversion coefficient not factor but I think it means the same thing.
