Jul 16th, 2024, 12:43pm
Power and statistical analysis in asd2004 (Read 2665 times)
Turin
Greece
Mar 02nd, 2012, 3:26am
I am using ads and I would like to find out the power consumption of the circuits in the project.How do you do power analysis in ads...?
Also can you do statistical(or monte carlo) simulation on transistors in ads?
Thanks!
Turin
Greece
Re: Power and statistical analysis in asd2004
Reply #1 - Mar 6th, 2012, 11:55am
No suggestions anyone?
Reply #2 - Mar 7th, 2012, 6:39am
Can't you measure the current through the voltage sources and use that to compute the power?
I'm sure you can do statistical analysis in ADS, though I haven't done it myself.  You'd need to have model cards/library that defines the variations.
Turin
Greece
Reply #3 - Mar 7th, 2012, 7:55am
I guess I will have to do it as such...I was hoping to avoid it since the circuit are fairly large by find an automatic way to compute power....
As for the statistical I will probably just do a parameter sweep and get what I want....
Thanks!
