tomaul1
Hello, let's say I have this module:
module ALU( input carryIn , input [2:0] func , input [31:0] left, right , output reg carryOut , output reg [31:0] out );
always @(left or right or func or carryIn) case (func) 3'b000: {carryOut, out} = left + right + carryIn; //add 3'b001: {carryOut, out} = left - right – carryIn; //sub 3'b010: {carryOut, out} = {1'b0, left & right}; //and 3'b011: {carryOut, out} = {1'b0, left | right}; //or 3'b100: {carryOut, out} = {1'b0, left ^ right}; //xor 3'b101: {carryOut, out} = {1'b0, ~left}; //not 3'b110: {carryOut, out} = {1'b0, left}; //left 3'b111: {carryOut, out} = {1'b0, right >> 1} ; //shr endcase endmodule
and the following module that incorporates the ALU:
module alu_acc( output reg [31:0] acc_reg , input [31:0] in , input [2:0] func , input cin , output cout , input clock ); wire [31:0] out;
ALU alu(.out (out) , .carryOut (cout) , .carryIn (cin) , .left (in) , .right (acc_reg) , .func (func) ); always @(posedge clock) acc_reg = out; endmodule
At every positive edge of the clock, we apply {func,cin,in}={..}, so if we apply: {func, in, cin} = {3'b000, 31'b101, 1'bx} // acc_reg = 31'b101 {func, in, cin} = {3'b010, 31'b010, 1'b0} // acc_reg = acc_reg + 31'b10 + 0 {func, in, cin} = {3'b011, 31'b011, 1'b1} // acc_reg = acc_reg - 31'b11 - 1 then we get acc_reg=31'b011.
I am asked to modify the ALU module in order to make the same operations to a string of numbers, in which the negative numbers are represented in 2's complement. I can't figure out what to modify, where to modify or anything else...
Please help me with this, I am just starting to learn verilog and Digital Integrated Circuits, so I am limited to ideas for solving this.
Thank you very much!
