Jul 16th, 2024, 12:47pm
How to plot power in dBm using Calculator of Spectre (Read 1994 times)
DoYouLinux
Mar 05th, 2012, 11:53pm
It seems easy, but I could not make it anyway.
As you might know already, in Cadence Spectre, we can plot the spectrum of a signal (say, output of an amplifier) using "dft" function of the Calculator. But, this gives the magnitude of the result in Volt. When I use "dBm" function, it gave me wrong calculation which did not correspond to the value of conversion from Volt to dBm. Also, I could not find the definition of the function "dBm" and also no specification for the reference resistance ...
Could anyone suggest me how to plot the spectrum in dBm on the Y axis please ??
Thanks a lot in advance Smiley
DYL
weber8722
Re: How to plot power in dBm using Calculator of Spectre
Reply #1 - Mar 6th, 2012, 4:09am
I think dbm will take 50Ohms as reference. So if you want full control on Rref better use your own expression.
