Jul 17th, 2024, 5:25am
ADPLL spurs (Read 2208 times)
rfmems
ADPLL spurs
Mar 08th, 2012, 1:27am
If we assume TDC and DCO completely linear, do we still have spurs unique to ADPLL? (except spurs due to SD modulator pattern, which is common to fractional-N PLL)
Is TDC resolution a problem? cause the PLL couldn't correct phase error less than TDC resolution. But would that turn into spurs or just noise?
raja.cedt
Re: ADPLL spurs
Reply #1 - Mar 8th, 2012, 1:30am
no, but Qunatization noise and MASH can create some spurs at high frequency.
rfmems
Re: ADPLL spurs
Reply #2 - Mar 8th, 2012, 1:35am
Thanks raja.cedt!
I suppose TDC resolution is something unique to ADPLL. If the ADPLL fails to correct phase error less than TDC resolution, the quantization error could show up as spurs, am I right?
