rfmems
If we assume TDC and DCO completely linear, do we still have spurs unique to ADPLL? (except spurs due to SD modulator pattern, which is common to fractional-N PLL)
Is TDC resolution a problem? cause the PLL couldn't correct phase error less than TDC resolution. But would that turn into spurs or just noise?
