First of all, please, draw a schematic clearly, if you want people help you. Electronics does not like rush.
Use the M parameter for transistors and inductors and make the connection between components reasonably short. Voltages in the schematic are hardly readable. Currents are important as well!
At this step of the design, I'd suggest to use ideal inductors, capacitors and the ideal current source to bias M2.
You must place a capacitor between the output port and the output of the amplifier in order to bias the transistors properly
Matching network at the input is too complex. It is possible to match input with a series inductor at the gate and some inductance at the source. You can do some research. The methodology to do this exist. For example, you can read
http://www.amazon.com/Co-Design-Integrated-Receivers-International-Engineering/d...
