chandu28
vellore
I am M.S.Chandra Sekhar ,I am using HSPICE coding in mentorgraphics and simulating in ELDO....
the following is the comments after simulation and due to warning iam not able to get the o/p ports at all... please help awaiting you reply
sincerely M.S.Chandra Sekhar
***** ANALYSIS ....
Warning 439: In file "./controller.spi" line 44: + COMMAND .SETBUS: last Time point ignored. Warning 439: In file "./controller.spi" line 45: + COMMAND .SETBUS: last Time point ignored.
***** 0 error(s). ***** 2 warning(s).
***** GENERATION ...
Warning 107: NODE "RAS[1]": Less than two connections. Warning 107: NODE "RAS[0]": Less than two connections. Warning 107: NODE "CAS[1]": Less than two connections. Warning 29: Such messages will not be displayed in future. Set .option MSGNODE = 0 to receive all such warnings.
Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.OUT_R EFRESH not declared Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.OUT_A CTIVE not declared Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.OUT_P RECHARGE not declared Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.OUT_A UTOREFRESH not declared Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.OUT_R EAD not declared Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.OUT_W RITE not declared Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.R0 no t declared Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.R1 no t declared Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.C0 no t declared Warning 347: COMMAND .PRINT or .PLOT: element CONTROLLER.SDRAMCONTROLLER1.C1 no t declared
***** 0 error(s). ***** 23 warning(s).
this is the way I wrote the code....please help me I am new to this HSPICE and I followed manual properly.
.SETBUS RAS[1:0] RAS[1] RAS[0] .SETBUS CAS[1:0] CAS[1] CAS[0] .SIGBUS RAS[1:0] 3 0 0 0 00111111 .SIGBUS CAS[1:0] 3 0 0 0 11111111 Vreset reset VSS pattern 3 0 1n 0.1n 0.1n 10n 10111100 Vrefresh refresh VSS pattern 3 0 1n 0.1n 0.1n 10n 01001011 Venable enable VSS pattern 3 0 1n 0.1n 0.1n 10n 11110000 Vrd rd VSS pattern 3 0 1n 0.1n 0.1n 10n 00110011 Vwr wr VSS pattern 3 0 1n 0.1n 0.1n 10n 10111011 Vconflict conflict VSS pattern 3 0 1n 0.1n 0.1n 10n 10011001
V77 VSS 0 0 .tran 10n 200n 10n .plot tran v(*)
.probe tran v(controller.sdramcontroller1.out_refresh) .probe tran v(controller.sdramcontroller1.out_active) .probe tran v(controller.sdramcontroller1.out_precharge) .probe tran v(controller.sdramcontroller1.out_autorefresh) .probe tran v(controller.sdramcontroller1.out_read) .probe tran v(controller.sdramcontroller1.out_write) .probe tran v(controller.sdramcontroller1.R0) .probe tran v(controller.sdramcontroller1.R1) .probe tran v(controller.sdramcontroller1.C0) .probe tran v(controller.sdramcontroller1.C1)
.end
thanks in advance...
awaiting your reply...
sincerely, M.S.Chandra Sekhar
