Jul 29th, 2024, 1:24pm
Question about deterministic jitter (Read 3702 times)
busoni
Mar 22nd, 2012, 9:34am
Hello everyone! I am designing a CDR for a 5Gbps SERDES and I cannot figure out how to model deterministic jitter for my testbenches. From literature I've seen that the Dual Dirac model is applied. But if my jitter model applies jitter in the Dual Dirac fashion on each data-UI, the CDR cannot lock. So, should I let jitter take all values between the Dual Dirac edges? I mean, isn't this more "realistic"?
Re: Question about deterministic jitter
Reply #1 - Mar 26th, 2012, 2:49pm
Care to explain whats going on here?
I have designed a lot of CDR systems and SerDes devices
and I have no idea what  you are talking about.
busoni
Reply #2 - Mar 29th, 2012, 7:40am
During design spec I had to make a jitter budget. This defines the worst case eye closure in the CDR inputs. Eye closure is due to both random and deterministic jitter.
Now, I have to model random and deterministic jitter for simulations. I use Verilog-A and model random jitter as a normal distribution. For deterministic jitter I use a uniform distribution from which I randomly select the peak values(i.e. Dj_max or -Dj_max). Both jitter values are added per UI in the CDR data input thus closing the data eye.
Problem is that by adding +/-Dj in each UI, the CDR loop cannot track the input signal. That is why I wonder if I should use all intermediate values between [-Dj_max, Dj_max] and not just the peak ones.
I hope it's clear now Smiley
Reply #3 - Apr 8th, 2012, 12:50pm
You need to improve your definition of jitter here.
Most of them are going to be be random in nature and spread in a gaussian manner.
What you are describing sounds like you are jumping from min to max of the extremes of some jitter constant.
BackerShu
Reply #4 - Jul 18th, 2012, 10:34pm
CDR system's jitter includes random jitter and deterministic jitter; yet, when we talk about this, we are thinking about the recovered clock or data, which are outputs of the CDR.
For the input of CDR, I cannot see any necessity to put the "deterministic jitter" (which is not a right way to define DJ, I just use your terms).  I think we just need to put random data, or PRBS data as usually the input of a CDR circuit, with some Gaussian distributed noise as loose-electron mentioned.
Correct me if I am not right.
