Aug 1st, 2024, 7:11am
High-pass filter having poor ECG transient response (Read 2909 times)
gido
Mar 22nd, 2012, 12:22pm
I have designed a fully differential passive high-pass filter for ECG and in running the transient response, I get the common mode to be decreasing and settling at a longer time.
How best can i resolve this? ( make the common mode zero).....
Attached is the fully differential transient response.
gido
Re: High-pass filter having poor ECG transient response
Reply #1 - Mar 22nd, 2012, 12:24pm
Pls attached too is the schematic of the passive fully-differential high-pass filter. I subtract the voltages at the two outputs to get the response
wave
Reply #2 - Mar 22nd, 2012, 1:45pm
With limited information, this seems fundamental.
Single HPF have settling times and a differential step on a pair may have asymmetry.
Is your input DC same as output CM (0V) ?
Are your waveforms DC balanced?
You might want to plot single ended inputs, with DC content.
How to you plan to amplify this?
Wave
gido
Reply #3 - Mar 22nd, 2012, 2:07pm
wave wrote on Mar 22nd, 2012, 1:45pm:
Wave
yeah, my input DC is same as output CM(0V)
I plotted single ended transient and the DC contents are same(0V).
One thing is, the fully differential transient response for a sinusoidal input has a constant CM that is zero throughout.
