Jul 31st, 2024, 5:15pm
Decreasing common mode level for Transient response (Read 1658 times)
gido
Apr 01st, 2012, 2:27am
can there be a situation whereby the single ended outputs of a fully differential HPF will have zero DC level but when you subtract the two outputs( taken differentially), you get the output common mode level to be zero initially and decreasing to settle at a lower value after some time for the transient response?
Re: Decreasing common mode level for Transient response
Reply #1 - Apr 1st, 2012, 1:38pm
IF I understand the question -
For an ideal device with perfect CMRR, no.
For real world circuits with less than perfect CMRR and adaptive
common mode feedback systems - then yes.
RobG
Bozeman, MT
Reply #2 - Apr 2nd, 2012, 9:36am
I agree with Jerry about common mode (the common mode is set by a feedback circuit whose gain is not infinite), but the question doesn't make sense to me... if you subtract the two outputs you get the differential output. To get the common mode you average the two signals (add them together and divide by two).
