Jul 17th, 2024, 3:23am
peaking in frequency V.S. overshoot in time domain? (Read 6785 times)
henrytqy
Apr 08th, 2012, 7:52pm
Hi, guys
I'am very confused with the concept of peaking and overshoot.
Dose they descripe the same thing just in the different domain?
If not, is there any relationship between them?
Thanks a lot~~~
aaron_do
Re: peaking in frequency V.S. overshoot in time domain?
Reply #1 - Apr 9th, 2012, 1:23am
They are related through the circuit Q, or damping ratio.
regards,
Aaron
henrytqy
Reply #2 - Apr 9th, 2012, 3:29am
aaron_do wrote on Apr 9th, 2012, 1:23am:
regards,
Aaron
I know that in a 2nd order system, there is a standard description about Q or damping ratio. How about higher order?
Recently, I have desgned a cascade AMP which is used in the open-loop condition. In the bode diagram, the plot(Mag V.S. Freq) is flat without peaking, while in the trans digram, the overshoot(ring) is series. Do you know how I can solve this problem?
Thank you so much~~~
raja.cedt
Reply #3 - Apr 9th, 2012, 4:28am
post the schematic and plots...
Reply #4 - Apr 9th, 2012, 1:49pm
regards,
Aaron
Sometime yes and sometimes no.
So - Not necessarily
Peaking can refer to just the spectral response and at a particular frequency
Ringing and damping can refer to either reactive ringing or control systems and their
zeta (phase margin ) response.
(Both have Q, but a feedback system is generally looked at differently than a RL inductive ringing.)
Math types will say that that one is the same, and I will 50% agree with that.
henrytqy
Reply #5 - Apr 10th, 2012, 4:25am
raja.cedt wrote on Apr 9th, 2012, 4:28am:
This architecture is from one of papers I have read before,adding the interleaving active feedback make the whole system behaves equally as another topology in the next pic.
henrytqy
Reply #6 - Apr 10th, 2012, 4:30am
Assuming that, every G(s) has the form of A/(1+sRC), and Gf(s)=B/(1+sRC); So the whole poles,totally 6 with 2 real and 2 pair of compex, is splitting.
henrytqy
Reply #7 - Apr 10th, 2012, 4:36am
The splitting bring a more flatten AC gain response.
I also find that one pair of the complex pole will have a high reactive part due to the splitting.  So I guess maybe this is the reason why it has a high overshoot.
Is this right?
aaron_do
Reply #8 - Apr 10th, 2012, 5:24pm
You should be able to tell based on the Q of the complex poles.
Aaron
henrytqy
Reply #9 - Apr 11th, 2012, 6:32am
aaron_do wrote on Apr 10th, 2012, 5:24pm:
Aaron
Sorry, I don't understand your meaning. Do you mean that I should give out the Q of the pole?
aaron_do
Reply #10 - Apr 11th, 2012, 5:38pm
Actually I haven't really read up on this in a long time, but just browsing through my book, "Feedback Control of Dynamic Systems", if you have a transfer function which can be written as,
H(s) = (s-a)(s-b)
      (s-c)(s-d)(s-e)
you can do a partial fraction expansion to see the effect of each pole. Real poles result in no overshoot, but for complex poles, the amount of overshoot depends on the Q factor, or damping factor of the poles. It seems that you have the transfer function, so you should be able to tell if the overshoot is due to the complex poles just by looking at their Q factor...
regards,
Aaron
BTW, if you are injecting a large signal and looking at the overshoot, then the above explanation doesn't really apply since it is for a linear system.
