Jul 17th, 2024, 3:20am
IIP3 calculation with unequal two-tone inputs (Read 1705 times)
harryhu
Apr 12th, 2012, 4:58am
How to calculate IIP3 in two-tone tests with unequal input amplitude? For example, in the WCDMA out-of-band test case, the two tones at 190MHz and 95MHz offset are -30dBm and -45dBm, respectively.
aaron_do
Re: IIP3 calculation with unequal two-tone inputs
Reply #1 - Apr 12th, 2012, 5:28pm
IIP3 itself is defined for equal tones. You can find IM3 for unequal tones and then use those numbers to calculate the IIP3. Anyway, it is easy to work out the numbers graphically. For instance,
for magnitude response,
fundamental = b0x1
IM3 = b1x1x22
for log-magnitude response,
fundamental = X1 + B0
IM3 = X1 + 2X2 +B1
So you can work out B0 and B1. From there, IIP3 is the value of X (X1=X2 in this case) for which fundamental=IM3. Also note that you must chose X1 and X2 carefully since the upper and lower sidebands will be different.
Aaron
harryhu
Reply #2 - Apr 13th, 2012, 12:34am
Hi, Aaron. Thank you for the reply. It is useful to get back to the mathematical basics.
But I have a further question here. I am wondering if the method you gave may lead to different results if we use different fundamental tones to do the calculation (fundamental = b0x1). This maybe a problem when these two fundamental tones are out-of-band and experience different gains.
Song
aaron_do
Reply #3 - Apr 13th, 2012, 1:54am
Hi Song,
I don't really understand your question. If you change the frequency, the results can definitely be different, especially if the gain is different at the new frequency.
regards,
Aaron
philcorb
Reply #4 - Apr 13th, 2012, 2:58am
It is possible to calculate IP3 from an sstac analysis.  In which case one of the two input tone is considered small signal.
Supposing two tones are applied to a system, with Amplitudes A1 and A2 and frequencies f1 and f2 respectively.
The amplitude of the tone at 2f1-f2 (A_IM2) is determined by the amplitude A2
The amplitude of the tone at 2f2-f1 (A_IM1) is determined by the amplitude A1
OIP3 = A1 x sqrt(A2/A_IM2), in V
OIP3 = A2 x srqt(A1/A_IM1), in V
These equations can be referred to the input for IIP3
I hope this helps
harryhu
Reply #5 - Apr 14th, 2012, 6:54am
aaron_do wrote on Apr 13th, 2012, 1:54am:
Hi Song,
regards,
Aaron
Hi Aaron,
I am sorry I did not clearly express my thinking.
Supposing the amplitude of the input two tones at f1 and f2 are x1 and x2, respectively. And the output tones at 2f2-f1 (fIM3), f1 and f2 are PIM3, P1 and P2, respectively.
If we use the fundamental tone at f1 in the calculation,
P1 = x1 + b0
PIM3 = x1 + 2x2 +b1
We can have IIP3 = (P1-PIM3+2x2)/2;
However, if we use the fundamental tone at f2 in the calculation,
P2 = x2 + b0
PIM3 = x1 + 2x2 +b1
We can have IIP3’ = (P2-PIM3+x1+x2)/2;
IIP3 and IIP3’ are equal only if the gain at f1 and f2 are equal, which may not be true for all systems.
I hope the aforementioned explanation can make my question clearer. Thank you.
Song
harryhu
Reply #6 - Apr 14th, 2012, 7:03am
philcorb wrote on Apr 13th, 2012, 2:58am:
I hope this helps
Although I usually use analysis like PSS, QPSS in simulations, it is interesting to apply this idea in this case. Would you kindly please provide some references for detailed reading? Thank you.
aaron_do
Reply #7 - Apr 14th, 2012, 6:57pm
if the two tones are close enough, then the IIP3 for the lower and upper sideband will be the same. However, if they are not then they can be different as you pointed out. If you care about both upper and lower, then I would think you should either specify the two IIP3's separately, or only specify whichever is worse. Sometimes datasheets specify the worst case IM3 in a specific band, and sometimes they specify IIP3.
regards,
Aaron
philcorb
Reply #8 - Apr 16th, 2012, 7:13am
harryhu wrote on Apr 14th, 2012, 7:03am:
I hope this helps
I think I got this from one of Ken's papers
http://www.designers-guide.org/Analysis/intercept-point.pdf
