Jul 18th, 2024, 12:29pm
Transition filter starting at t=0? (Read 3315 times)
Bob Atwell
Tucson, AZ
Apr 12th, 2012, 9:55am
Is there a way to get a transition filter to start at t=0?
Assume I want a voltage to ramp from 0 to 1 in 1 sec.  starting at t=0 and ending at t=1.
v <+ transition(1, 0, 1) just starts at 1.
Using @initial_step and @timer doesn't seem to work either.  Am I missing something or is this just not possible?
Re: Transition filter starting at t=0?
Reply #1 - Apr 13th, 2012, 11:49am
If you do this:
real x;
@(initial_step)
 x = 0;
@(timer(1p))
 x = 1;
V(x) <+ transition(x,0,1);
I would think you could get pretty close to what you were looking for; you can make the argument to @timer smaller, though I guess it has to be always > 0.
Bob Atwell
Tucson, AZ
Reply #2 - Apr 13th, 2012, 3:18pm
Thanks, that was what I came up with too.
I don't like it much but I don't see any other way around it.
boulate
Reply #3 - Apr 19th, 2012, 10:36am
Why don't you do this?
V() <+ $abstime;
