Jul 18th, 2024, 2:21pm
verilogA example code of opamp (Read 7851 times)
seanpai
Apr 17th, 2012, 3:00pm
Hi guys, I am using a verilog-A to build up an behavior model of opamp for LDO. My opamp is a differntail input folded cascode and single ended output amp, and I am going to limit the output range of it between vdd-2 Vov and 2Vov. I looked at the opamp example in the ahdlLib, which is in the virtuoso library, and can't figure out the code in "soft output limiting" part in the bottom. The code is showed as follows:
"if (V(vout) > (V(vspply_p) - vsoft))
 I(cout, vref) <+ gm_nom*(V(vout, vspply_p)+vsoft);
 else if (V(vout) < (V(vspply_n) + vsoft))
 I(cout, vref) <+ gm_nom*(V(vout, vspply_n)-vsoft); "
In my understanding, the first and second line mean when Vout > Vdd-2 Vov, then I(out) will be gm*(V(vdd,vout)+2Vov) in my case. And the third and fourth line mean when Vout < vss(=0 in my case)+2Vov, then I(out) will be gm*(V(vout,0)+2Vov) in my case. Am I correct? Moreover, I don't know how the "V(vout, vspply_p)+vsoft" and "V(vout, vspply_n)-vsoft" are derived? Finally, why I(out) here become a Vout related value? It should be gm*vin_val by definition, right? Can anyone help me figure out these problems please? Thank you so much.
boe
Re: verilogA example code of opamp
Reply #1 - Apr 17th, 2012, 3:11pm
seanpai,
the model reduces gm if you get closer than vsoft to either rail.
- B O E
seanpai
Reply #2 - Apr 17th, 2012, 3:51pm
boe wrote on Apr 17th, 2012, 3:11pm:
seanpai,
- B O E
Hello B.O.E, Thank you for the reply. But I am still confused in  the equation "I(cout,vref) <+ gm_nom*(V(vout,vspply_p+vsoft))". Why gm_nom would time "(V(vout,vspply_p+vsoft))" here?   Lips Sealed
boe
Reply #3 - Apr 18th, 2012, 1:50pm
seanpai wrote on Apr 17th, 2012, 3:51pm:
Note that V(vout,vspply_p)+vsoft = 0  is equivalent to V(out) = V(supply_p)-vsoft.
- B O E
seanpai
Reply #4 - Apr 18th, 2012, 2:11pm
But why I(out) comes from gm_nom * "(V(vout,vspply_p+vsoft))" not gm_nom * "vin_val" here? And if V(vout,vspply_p)+vsoft = 0, we'll get a zero I(out), right? Always appreciate for your response. Thanks.
boe
Reply #5 - Apr 19th, 2012, 1:44pm
Seanpai,
Note that all contribution statements to one branch current are added.
- B O E
