Jul 18th, 2024, 7:28am
RF design and dc op analysis issue (Read 2704 times)
purplewolf
Apr 24th, 2012, 5:57am
I have designed some RF blocks  and i analysed them using standard analysis of PAC/PNOISE/PSS . It gave me desired performance. Now i discover when i run dc analysis that some critical devices are in linear or sub-threshhold region. Now since the design is sent to manufacturing. What performance should i except??
aaron_do
Re: RF design and dc op analysis issue
Reply #1 - Apr 24th, 2012, 5:25pm
I think you can just check process corners and find out. Vary supply and temperature too. I assume you've properly modeled your system...
rfcooltools.com
Reply #2 - Apr 25th, 2012, 9:28am
purplewolf,
Subthreshold operation is sometimes a more common mode of operation with deep submicron processes.  The primary drawback of this region of operation is vt mismatch.  vt mismatch always occurs in processing, and one way to mitigate these effects is to operate the device in saturation and increase the overdrive voltage such that vt mismatch becomes a smaller factor in current variations.
http://rfcooltools.com
Reply #3 - May 5th, 2012, 10:17am
purplewolf wrote on Apr 24th, 2012, 5:57am:
Something very basic here.
Before you start doing all the detailed simulation
work that you are describing, you need to get
the DC operating point right.
Is "manufacturing" mean a fabrication of some test devices,
or put into a manufactured product going out for sale?
Either way, you probably have problems.
purplewolf
Reply #4 - May 7th, 2012, 7:19am
For current mirrors its okay as  all devices need to be in saturation..
but for block like gilbert cell mixer which is non-linear and a driven circuit, should dc analysis be performed on all corners and check every device in saturation.?
