Jul 30th, 2024, 7:18am
Clock generator for latched comparator (Read 2467 times)
gsensor
Apr 24th, 2012, 2:40pm
Hi guys,
I'm currently designing a latched comparator working with a 200 MHz ideal clock in Spectre Simulator with CMOSP13 IBM technology. I don't know if its best to implement this 200 MHz clock on-chip or to have an output signal linked to an off-chip clock generator. As I have no experienced with circuit working with a clock, I don't know which option is best in terms of precision ? My guess is going with an on-chip clock, but which topology,  taking in consideration low complexity and low space ? A VCO, or do I need a PLL for this frequency ?
Thanks for your help,
gsensor
carlgrace
Berkeley, CA
Re: Clock generator for latched comparator
Reply #1 - May 11th, 2012, 1:27pm
The answer to this really depends on your specs.  An off-chip clock that you buffer on-chip is MUCH, MUCH, MUCH simpler than implementing a PLL.  So your decision should be like this:
1.  Can I make an off-chip clock work?  Why not?  Can I address any of the reasons why not in a simple way?
2.  I have no choice, I will need a PLL.
The thing is, if you have an on-chip clock generator, you will potentially have much better jitter performance (and programmablility) but you'll STILL need an off-chip clock for a reference.
Reply #2 - May 24th, 2012, 1:33pm
external clock if available elsewhere in your system, probably crystal generated.
Take whatever the available frequency is and divide it down inside your design to the desired frequency.
Things like RC oscillators etc are not very accurate.
