Jul 31st, 2024, 11:23am
Clock generator for latched comparator (Read 3404 times)
gsensor
Apr 24th, 2012, 3:38pm
Hi guys,
I'm currently designing a latched comparator working with a 200 MHz ideal clock in Spectre Simulator with CMOSP13 IBM technology. I don't know if its best to implement this 200 MHz clock on-chip or to have an output signal linked to an off-chip clock generator. As I have no experience with circuit working with a clock, I don't know which option is best in terms of precision ? My guess is going with an on-chip clock, but which topology,  taking in consideration low complexity and low space ? A VCO, or do I need a PLL for this frequency ?
Thanks for your help,
gsensor
Re: Clock generator for latched comparator
Reply #1 - Apr 24th, 2012, 5:23pm
external crystal generated clock if possible
gsensor
Reply #2 - Apr 25th, 2012, 11:34am
Why ? Isn't an external clock more imprecise due to propagation delays and external noise, than an on-chip clock with a good layout design ?
boe
Reply #3 - Apr 25th, 2012, 1:37pm
Gsensor,
crystals are resonators with very high Q, which minimizes errors.
- B O E
gsensor
Reply #4 - Apr 26th, 2012, 8:14am
Ok, thanks guys for your advice. I will use an external crystal oscillator.
Reply #5 - May 5th, 2012, 10:41am
Q of an external crystal is 10E5, which you can not do with an internal oscillator.
