Jul 18th, 2024, 12:33pm
step response analog LPF (RC Low Pass), abrup jump (Read 3218 times)
nzborsti
Apr 26th, 2012, 1:42am
Hello there,
I wrote a Verilog AMS Modle for a simple analog LPF:
//Verilog-AMS HDL for "test", "filter2" "verilogams"
`include "constants.vams"
`include "disciplines.vams"
module filter2 ( in, out);
input in;
output out;
electrical in,out;
parameter real tau1= 0.66 from (0:inf);
parameter real tau2= 0.074 from (0:inf);
real Kn;
// passive filter lead lag
analog begin
Kn=tau2/(tau1+tau2);
V(out)<+Kn*laplace_nd(V(in), {1/tau2,1},{1/(tau1+tau2),1 });
$bound_step(1n);
When I looked closer at the step response of the filter I saw that there is a abrupt jump in the output signal at the time where the step is applied to the input. That is a bit strange since the output should be continious. Does anyone know what's going wrong here? I am using AMS  solver in ADE XL.
Thanks for your help.
boe
Re: step response analog LPF (RC Low Pass), abrup jump
Reply #1 - Apr 27th, 2012, 11:11am
Nzborsti,
nzborsti wrote on Apr 26th, 2012, 1:42am:
Hello there,
... That is a bit strange since the output should be continious. Does anyone know what's going wrong here?
No. You seem to have feed-through from the input.
- B O E
nzborsti
Reply #2 - May 2nd, 2012, 12:49am
but how can i avoid this. I mean it is  a simple LPF , there is not much that I can change, is there?
boe
Reply #3 - May 2nd, 2012, 12:13pm
Nzborsti,
remove the feed-through.
- B O E
