Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 1
st
, 2024, 11:27am
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› TRANSISTORS IN CUT-OFF
Previous topic
Next topic
TRANSISTORS IN CUT-OFF (Read 1839 times)
gido
May 14
th
, 2012, 4:05pm
Hello all,
can i make my transistors operate in cut-off just to make use of the high output resistance of transistors in cut-off region in cadence???
IP Logged
vivkr
Re: TRANSISTORS IN CUT-OFF
Reply #1 -
May 15
th
, 2012, 7:43am
well, you can! but what would you gain by doing so? I suppose that you want to put your transistors to some good use in your circuit, a task incompatible with keeping them off all the time.
Vivek
IP Logged
Reply #2 -
May 20
th
, 2012, 10:43am
you looking to create a high value resistance?
If so results using this method will not be either predictable or consistent
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
