Jul 17th, 2024, 7:34pm
Analog phase shifter (Read 2177 times)
kr106
sweden
May 16th, 2012, 6:35am
I already made fixed phase shifter but I need to make an (variable) analog phase shifter (0-180°) with variable control voltage (0-13V) at 2.45 GHz centre frequency using ADS tools. Anyone can give me idea about whole circuit schematic or provide me any made schematic.
raja.cedt
Re: Analog phase shifter
Reply #1 - May 16th, 2012, 6:49am
hello,
what kind of signal you are going to delay? If it is a digital signal better go for gilbert mixer which gives variable phase shift, but it need I &Q signals. If they pure analog i donno may be RC phase shifter with Controlled R
raj.
Reply #2 - May 20th, 2012, 10:17am
is this purely for a math model or are you going to need to make it out of transistors later on?
aaron_do
Reply #3 - May 20th, 2012, 5:57pm
The control voltage sounds very large (13 V). What technology are you using? At low frequencies, you can use an op-amp based all-pass filter. There are also passive RLC methods to design an all-pass filter.
