Jul 17th, 2024, 1:30am
Outputmatch of LNA (Convert differential output to single output without balun) (Read 1547 times)
eason.RFIC
Jun 02nd, 2012, 3:40am
Hi Guys :
I design a LNA with a differential output , but when tapeout , i want to measure the LNA individually ,so i want to convert the output node into a single output , but i don't want to use a balun ,i want use a circuit to achieve the convert . Anyone has some advise for me to design a circuit convert the differential output to a single output ! thanks
View Profile eason.RFIC eason.RFIC   IP Logged
RFICDUDE
Re: Outputmatch of LNA (Convert differential output to single output without balun)
Reply #1 - Jun 4th, 2012, 4:25am
The easiest thing to do is to use single ended matches on each output that run to connectors and then buy a connectorized wideband balun to make the measurement. This way you can measure each output individually and/or combined through the balun.
I suppose you could synthesize what you want by designing a lumped element circuit that converts the differential signals to in-phase signals then have a network to combine the power.
The differential to in-phase is a phase rotation of +90 and -90 (or +270) degrees. You might be able to use lumped element equivalents to transmission lines to get the desired phase shifts.
If you can achieve the desired phase shift and impedance match then all you need is a power combiner (either external or a lumped element equivalent).
It just depends on how much time you want to put into designing the lumped element circuits and how well the circuits perform when component variation and board parasitics are considered.
