Aug 2nd, 2024, 5:14am
inverter delay (Read 4207 times)
raja.cedt
inverter delay
Jun 04th, 2012, 1:52am
hello all,
can any one please tel me how inverter delay can controlled.... Basically delay is charging rate, so either I has to increase current or capacitance  has to decrease.
1. So in-principle increasing size should n't change the delay (neglect parasitic cap) due to increase in I and Cap simultaneously. is this correct???
2. What about current steering...this will increase current without increasing the cap, so what is the bottle neck here????
3. Is there any way to get fine delay in a given technology?
raj.
Raj.
boe
Re: inverter delay
Reply #1 - Jun 5th, 2012, 11:48am
Hi Raj,raja.cedt wrote on Jun 4th, 2012, 1:52am:
For a given load, increasing the driver size reduces the delay.. Note that parasitics are often dominant here (if you drive long lines).
- B O E
aaron_do
Re: inverter delay
Reply #2 - Jun 5th, 2012, 5:50pm
if you want more delay, can't you just increase the gate length?
Aaron
Re: inverter delay
Reply #3 - Jun 5th, 2012, 9:48pm
what are you trying to do?
create a variable delay? Or what?
Lex
Eindhoven, Holland
Re: inverter delay
Reply #4 - Jun 6th, 2012, 2:13am
You want a finely controlled delay. I'd say you'd need go digital to do so. Some controllable logic in which you can program the delay (e.g. via a set of flipflops) combined with an accurate clock is very process independent as well.
RobG
Bozeman, MT
Re: inverter delay
Reply #5 - Jun 6th, 2012, 8:22am
Your belief that delay will be constant for the inverter sounds reasonable only if you don't include loading. Power supply and the slope of the driving voltage also affect timing. You obviously need bigger devices to drive a bigger load. A long time ago I found that the best speed/power tradeoff was with driving inverter 1/3 the size of the load gate. Not sure if that is still true.
If you limit the swing like is done with PECL you can get faster response at the expense of having static current.
rfcooltools.com
Re: inverter delay
Reply #6 - Jun 7th, 2012, 11:59am
Lowering or raising the supply will change the delay.
http://rfcooltools.com
Re: inverter delay
Reply #7 - Jun 8th, 2012, 8:02am
Hi Raj,
What's your purpose of controlling the delay of inverters? You asked the way to get fine delay. How fine? <10ps or ??
Even on-chip microstrip lines are adopted to get very fine delay, like 10ps/step. Please refer the following paper.
Quote:
 A 10 ps Resolution 1.6 ns Tuning Range CMOS Delay Line for Clock Deskewing in Data Recovery Systems
Gogaert, S.; Steyaert, M.
Solid-State Circuits Conference, 1995. ESSCIRC '95. Twenty-first European
Publication Year: 1995 , Page(s): 54 - 57
IEEE Conference Publications
Yawei
