Aug 15th, 2024, 11:11pm
How to bias a Passive mixer ? (Read 2685 times)
Muhammed
Jun 13th, 2012, 5:41am
Hello all .. i want to ask about biasing Passive mixer just 4 MOS as switches .. but i want to set the Dc Output Common mode .. for them ... any idea how can i do this without large flicker noise due to dc bias
thanks
vivarf
Re: How to bias a Passive mixer ?
Reply #1 - Aug 2nd, 2012, 5:12am
This might relates to quite complicated analysis you can find in many published work in IEEE. For simple design you want to bias Vgs=Vth to minimize flicker noise.
View Profile veeater   IP Logged
RFICDUDE
Reply #2 - Aug 4th, 2012, 5:12am
I suppose you could use a resistor divider from a power supply to set the common mode to some fraction of the supply. This voltage will obviously track supply changes and also potentially let noise on the supply couple to the mixers, but it is simple. The gate bias would need to be supply referenced too such that the overdrive on the switches doesn't vary with supply.
