samiran
Earlier I had IC514 installed and I could run a ocean script from UNIX terminal after changing prompt to ocean by typing ocean command.
Now I have switched to IC614. From the ADE XL window, I have saved an ocean script for a transient simulation of an CMOS inverter for different corners. The simulation settings is running fine from ADE XL. I have executed the ocean script from CIW window by typing load("inv1_test1.ocn") command. But, when I switch to ocean promtp from UNIX terminal and tried to run the same script by the same command, it failed. Please have a look at the outputs from CIW window (success) and UNIX terminal ocean prompt (failure):
CIW [Success]:
load("inv1_test1.ocn") ------------------------------- Run Setup Summary: ------------------------------- Run Mode: "Single Run, Sweeps and Corners"
1 Test (enabled) 1 Point Sweep (enabled) 4 Corners (enabled) Nominal Corner ------------------------------- 1/5 completed. 2/5 completed. 3/5 completed. 4/5 completed. 5/5 completed. net /net3 selected but not highlighted net /net5 selected but not highlighted *Info* The history of this OCEAN XL run is saved as "Ocean.0".
*Info* The results of this run are saved in "/research/samiran/simulation/SC_1BY2_11ELEMENT_NRTI_TESTBENCHES/INV1_TEST1/ade xl/results/data/Ocean.0.rdb".
*Info* The simulation data from this run are saved in "/research/samiran/simulation/SC_1BY2_11ELEMENT_NRTI_TESTBENCHES/INV1_TEST1/ade xl/results/data/Ocean.0".
Detailed Expression Summary: =========================== Parameters: None. Test: SC_1BY2_11ELEMENT_NRTI_TESTBENCHES:INV1_TEST1:1 Nominal Corner: output value /net5 wave /net3 wave Corner FF: output value /net5 wave /net3 wave Corner FNSP: output value /net5 wave /net3 wave Corner SNFP: output value /net5 wave /net3 wave Corner SS: output value /net5 wave /net3 wave Expression Summary: =================== Parameters: None. Test: SC_1BY2_11ELEMENT_NRTI_TESTBENCHES:INV1_TEST1:1 output min max /net5 wave wave /net3 wave wave *Info* There are no specs. If you have defined specs for some tests, ensure that some of those tests are enabled.
t
UNIX Terminal ocean prompt [Failure]:
Loading oasis.cxt Loading adexl.cxt Loading asimenv.cxt Loading analog.cxt Loading par.cxt Loading socket.cxt Loading alvs.cxt *Error* Library "SC_1BY2_11ELEMENT_NRTI_TESTBENCHES" does not exist.
*Error* There is no OCEAN XL session. Use ocnxlTargetCellView() command to create a session. Loading spectrei.cxt Loading relXpert.cxt Loading awv.cxt ERROR (ADE-5726): Unable to open config (SC_1BY2_11ELEMENT_NRTI_TESTBENCHES INV1_TEST1 schematic). t
Why the same script is failing to run from UNIX terminal ocean prompt?
Thanks Sam
