Jul 17th, 2024, 1:21am
Large gate resistance (Read 3730 times)
kollayliu
Jun 18th, 2012, 7:02am
I'm starting with a new technology. I just noticed that the gate resistance in this technology is quite large. For example, for a regular MOSFET and a RF MOSFET both in a size of 100um/0.18um (2 fingers), the gate resistance are 458ohm and 92ohm respectively.
I'm not sure if these value are reasonable. If they are not reasonable, what do you think are the reasons for these wrong values?
Attached is my test bench.
Thanks.
« Last Edit: Jun 18th, 2012, 8:14am by kollayliu »
kollayliu
Re: Large gate resistance
Reply #1 - Jun 18th, 2012, 7:18am
BTW, the gate resistance can be reduced by using more fingers. For example, for a RF MOSFET in a size of 100um/0.18um, following is the relationship between number of figures and gate resistance
Number of fingers     Gate resistance
2                                 92 ohm
5                                 9 ohm
20                                4 ohm
If these values are reasonable?
Reply #2 - Jun 18th, 2012, 3:04pm
what is the resistance per square of the polysilicon layer that makes the gate?
Is it a silicided polysilicon?
Silicided Poly are the most common and will be under 10 ohms per square.
Non-silicided poly runs up to 200 ohms/square
Reply #3 - Jun 27th, 2012, 6:35am
Hi Kollayliu,
It is not clear how do you get the value of gate resistance in your simulation. Could you please explain the method you measure gate resistance?
It is strange that the gate resistance for a regular MOSFET is 5 times of the gate resistance for a RF MOSFET. In fact, they have the same material in CMOS technology. So they should have equal gate resistance if their gate length/width/finger are equal to each other.
Yawei
nadroit
Reply #4 - Jul 9th, 2012, 12:10pm
Hello kollayliu
  How did you measure gate resistance in cadence? is it from dc simulation? I do not see any gavte resistance parameter in operating point information. lease let me know
