Sep 8th, 2024, 10:43pm
Second-Stage Folded Cascode amplifier CMOS ? (Read 11704 times)
gsensor
Jun 20th, 2012, 7:29pm
I'm working with 0.13 um CMOS (IBM) technology with a 2.5V supply.
I have designed successfully a one-stage folded cascode amplifier, providing low noise and low power by using large length device for cascode mirrors. This op-amp as the following characteristics:
Open-loop gain: 75 dB
PSSR+: 80 dB
PSSR-: 75 dB
Output swing: 0.4V-2.1V (Gnd+Vth ,Vdd-Vth)
Input voltage: 0.3V-1.25V (I will use this op-amp only with this range of input vcm..)
Power: 32 uW
Bandwidth: 3 kHz (limited by C load)
C load=2pF
As I need a rail-to-rail output swing, low power dissipation, a bandwidth of 4 kHz  and an open-loop gain of at least 80 dB, I have tried, unsuccessfully to add a second stage to this op-amp, using a simple indirect feedback compensation  (see below).
The problem is that I keep getting a huge offset no matter how I size the 2 transistors of this second stage....What I'm I doing wrong ? Is there a proper way to design this stage ?
If this is not possible with my specifications, what other second stage could provide me the rail-to-rail output swing I'm seeking, without an offset voltage bigger than 200 uV (without mismatch variations) for an input common voltage of 0.3V to 1.2V and without increasing dramatically power consumption ?
Thanks a lot for your help !
gsensor
gsensor
Re: Second-Stage Folded Cascode amplifier CMOS ?
Reply #1 - Jun 20th, 2012, 7:50pm
The devices operating points appearing on the image are obtained with the open loop gain test.
W/L:
T3-T4: 6.5u/30u
T5-T9:10u/1u
T1-T0: 2u/20u
T20-T10: 23u/60u
T59 and T65 ?
Lex
Eindhoven, Holland
Reply #2 - Jun 21st, 2012, 12:33am
Vds of the T65 is quite low, feedback configuration not shown, so difficult to conclude why (at least, for me Wink).
And to be honest, 200 uV static offset is probably way below the mismatch variation.
gsensor
Reply #3 - Jun 21st, 2012, 12:21pm
Hi Lex,
thanks for your response.
When I simulate the offset voltage, either T3-T4 and T5-T9, or T0-T1 and T10-T20 is off or in triode region, depending of the vcm I use. I can size T59 and T65 to a way that they are both in saturation and offset voltage is minimized, but it only works for a specific vcm input, let's say 400 mV. If I use vcm=1V I still get that huge offset..
For mismatch, I meant, 200 uV without considering mismatch variations in simulations..
« Last Edit: Jun 21st, 2012, 3:29pm by gsensor »
Lex
Eindhoven, Holland
Reply #4 - Jun 22nd, 2012, 12:59am
If that is the case, that means you don't have a bias loop, meaning you're probably simulating open loop? Frankly speaking, I think the problem is related to your test bench.
Anyhow I don't see much wrong with this circuit. Sure there are ways to improve (e.g. cascoding 2nd stage to reduce early effect), but not much to win imho.
gsensor
Reply #5 - Jun 22nd, 2012, 10:03am
I test the voltage offset in a close loop configuration (voltage follower) : Vin+ = Vcm and Vin-= Vout.
The image attached shows the transistors operating in that configuration, for an input voltage of 0.3 V (Vcm=0.3V)...To which I get a huge offset of 2.18V. In open-loop configuration, every transistors, including T59 and T65 are in saturation. Althougth, I also have a phase starting at +150 degrees ?
T59=5u/60u and T65=(2.7*5u)/60u
Could you give me some guidelines on how to set the size of the second-stage transistors ?  Is the problem caused by the first-stage ?
« Last Edit: Jun 22nd, 2012, 11:04am by gsensor »
wave
Reply #6 - Jun 22nd, 2012, 12:47pm
Clearly you are NOT in saturation on T58, T59, T7.
Your VDS are collapsing due to PFB.
Try swapping +/- inputs.
Also your + input is 1V not 0.3 as you state.
gsensor
Reply #7 - Jun 22nd, 2012, 2:25pm
Right, Vcm= 1V on the schematic shown, sorry for that.
I have swap + and - inputs, and my problem is solved! No more huge offset!..I had tried everything, without considering that my circuit configuration might have been the problem...hughh
Thanks wave !!!
Lex
Eindhoven, Holland
Reply #8 - Jun 26th, 2012, 12:27am
Well spotted wave! =)
