ppg
San Jose USA
Hi Ken,
Yes, I fully understand "noise added to crossing times" is much more accurate as "noise added to voltages" and i appreciated the detailed reading of the recipe you outlined. Two remarks though: 1. The frac-N (AD)PLL I am simulating with transient noise analysis is already modelled directly in the phase domain or at jitter level (as you recommended). 2. The results from analysis, the power spectral density of the phase deviations, must be accurately plotted for offset frequency ranging from 1 KHz to 100 MHz. Expected in band phase-noise is ~-105 dBc (for 2.4GHz carrier). Simulations run 10-20 ms simtime for smooth and accurate phase noise curves down to 1KHz. Sub-sampling at 200 MHz (from 0.5ns fixed step) via strobeperiod is meant to reduce the amount of data to be enter in 10*log10(psd(.)) function.
Regards, ppg
