Jul 15th, 2024, 9:30pm
VHDL code for booth multiplier (Read 118 times)
kalos
Jun 27th, 2012, 7:44am
I should realize the VHDL description of a digital multiplier that
realize Booth's algorithm (encoded in 2 bits) for two terms
represented on N and M bits, respectively, and with a result of N + M
bits.
I have attached the 2 files:
1)booth that should implement the booth's algorithm
2)test that should simulate
Are they correct to implement and simulate a booth's multiplier?
I wrote and simulated with ALDEC ACTIVE-HDL Student Edition.
Compile the code and i have 0 Errors, but in the simulation the result
of multiplication is "UUUU" and the WAVEFORM panel is empty.  so I
thought that the codes are wrong.
please help me.
1)
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity booths is
  GENERIC(k : POSITIVE := 7); --input number word length less one
  Port ( a,b : in STD_LOGIC_VECTOR (k downto 0);
         mul : out STD_LOGIC_VECTOR (2*k+1 downto 0));
end booths;
architecture Behavioral of booths is
begin
process(a,b)
variable m: std_logic_vector (2*k+1 downto 0);
variable s: std_logic;
begin
m:="00000000"&b;
s:='0';
for i in 0 to k loop
if(m(0)='0' and s='1') then
  m(k downto k-3):= m(k downto k-3)+a;
  s:=m(0);
  m(k-1 downto 0):=m(k downto 1);
elsif(m(0)='1' and s='0') then
     m(k downto k-3):= m(k downto k-3)-a;
     s:=m(0);
else
     s:=m(0);
end if;
end loop;
     mul<=m;
end process;
end Behavioral;
2)
library IEEE;
entity Testbench_di_Booth is
end Testbench_di_Booth;
architecture behavior of Testbench_di_Booth is
component booths
Port( a,b : in STD_LOGIC_VECTOR (k downto 0);
end component;
--Inputs
signal A : STD_LOGIC_VECTOR (7 downto 0):= "00000011";
signal B : STD_LOGIC_VECTOR (7 downto 0):= "00000100";
--Outputs
signal MUL : STD_LOGIC_VECTOR(15 downto 0);
begin
      --Instantiate the UnitUnder Test (UUT)
uut: booths PORT MAP
(a => A,
 b => B,
 mul => MUL);
 --Stimulus process
stim_proc: process
begin
--insert stimulus here
A<="00000011"; B<="00000100"; wait for 500 fs;
A<="00000110"; B<="00000111"; wait for 500 fs;
A<="00001011"; B<="00000100"; wait for 500 fs;
wait;
end process;
end;
