Jul 29th, 2024, 9:17pm
altergroup for model parameter. (Read 4390 times)
michaelFCT
Jun 27th, 2012, 8:55am
Hi guys,
I'm trying to alter a model parameter, noimod to 1.
I've tried including a .scs file with the following:
ag1 altergroup {
     model pch bsim3v3 type=p noimod=1
     model nch bsim3v3 type=n noimod=1
but I get an error, saying that pch and nch was previously defined by a modelgroup in "xxx.scs".
I've tried using the following:
ag1 altergroup {
     model pchmod bsim3v3 type=p noimod=1
     model nchmod bsim3v3 type=n noimod=1
But then I get a warning that pchmod and nchmod have not been defined, therefore will be ignored.
I've tried this too: spectre.envOpts useAltergroup   boolean nil , but it did not help.
What am I doing wrong or is there another way to alter a model parameter (or a modelgroup parameter)?
Spectre subversion: 10.1.1.200.isr13
Cadence version: IC6.1.5-64b.500.5
Thanks.
Re: altergroup for model parameter.
Reply #1 - Jun 28th, 2012, 9:55am
Have you tried using a simple alter statement?
enablePchNoiseMod alter mod=pch param=noimod value=1
enableNchNoiseMod alter mod=nch param=noimod value=1
michaelFCT
Reply #2 - Jun 29th, 2012, 6:36am
Hi Ken,
Yes, actually that was my first choice after following a response by Andrew Beckett (http://www.cadence.com/Community/forums/p/21354/1307135.aspx).
Using a simple alter statement produces the following result:
ERROR (SFE-421): Undefined parameter name 'noimod'.
Noimod does exist in my model parameters.
Could this have anything to do with modelgroups?
Thanks.
Reply #3 - Jun 29th, 2012, 10:26am
You probably need to put noimod in quotes.
