Jul 17th, 2024, 3:16am
Relating phase noise & jitter (Read 2074 times)
Sharath Raju
Jun 28th, 2012, 12:06pm
I am trying to calculate the phase noise of a clock signal given its jitter. I have used the equation given in Hajmiri's book - The Design of Low Noise Oscillators. I have attached a snapshot of my hand calculations.
As shown in the calculations, the calculated phase noise is -67 dBc/Hz whereas the lecture slides report it to be -55 dBc/Hz.
Link to Lecture slide: https://ccnet.stanford.edu/cgi-bin/course.cgi?cc=ee315b&action=handout_download&...;
handout_id=ID131637959122829
Chapter 13, slide 12
Could you please comment on the difference ?
Sharath
biff44
Re: Relating phase noise & jitter
Reply #1 - Jul 7th, 2012, 10:38am
Sorry, that link does not open up a lecture page.  But what you are calculating seems to be somewhat wrong.  Phase noise is a broadband noise. Phase noise is typically measured from 100 hz to 10 Mhz from the carrier, and the level at each frequency offset point varies.
So if you have a phase noise measourement, and want to turn it into rms jitter, you have to INTEGRATE it over the frequency limits of 100 Hz to 10 MHz, do a little more math, and then you have an answer.
Possibly the example you were looking at was not phase noise at all, but relating a discrete freuqency spurious sidband to the jitter that one tone would cause?
here is a spreadsheet "allan variance from phase noise" that might help your understanding:
http://www.wenzel.com/documents/spread1.htm
there are other spreadsheets out there for jitter to phase noise calculation
Rich
Maguffin Microwave
