Jul 17th, 2024, 3:17am
Pseudodifferential Signaling (Read 1301 times)
DDC
Jul 03rd, 2012, 12:07am
I have the problem that the maximum supply voltage I can use is too small for the design of a gilbert cell. I decided to bias the transconductance stage of the gilbert mixer without a current mirror at the button. So I need to bias the BJT transistors like current mirros itself. Can somebody explain, what is the drawback of this ? I heard that when doing so you won't have AC common mode voltage rejection. Is that right and why ? Thanks for response.
raja.cedt
Re: Pseudodifferential Signaling
Reply #1 - Jul 3rd, 2012, 5:42am
how much vdd you have? if it is so low use modified Gilbert cell which has only 2 transistors in the stack from vdd to gnd.
thanks,
raj.
