Jul 30th, 2024, 11:17am
use of spectre bjt models (Read 2594 times)
fab32
Jul 13th, 2012, 7:26am
I would like to ask a question about the simulation spectre models of btj.
Is it possible to make a simulation with two different bjt models of the same library?
I would like to use the old model ("file A.scs") for some transistors in the circuit and to use the new model ("model Anew.scs") for other transistors in the same circuit.
Thanks for the help.
Re: use of spectre bjt models
Reply #1 - Jul 18th, 2012, 10:03am
I think this would be difficult, unless you changed the model names -- instead of "npn" make them "npn_new" in the library as well as the netlist.  Even then, I think probably some parameter names would appear in both libraries, and you'd have to deal with those collisions.
fab32
Reply #2 - Aug 2nd, 2012, 12:46am
Ok, thanks a lot
