Sep 19th, 2026, 10:43am
Temperature measurement (Read 6443 times)
mixed_signal
Jul 17th, 2012, 4:43pm
I need to test a circuit based temperature sensor with the following specs. Can someone suggest a good platinum RTD (with vendor)?
Range: -20 to 30c
Accurac +-0.1C
resolution 0.01c
Re: Temperature measurement
Reply #1 - Mar 24th, 2014, 1:57am
What did you do to keep the temperature of the circuit from deviating from that of the platinum RTD?
Yawei
