Jul 29th, 2024, 11:16pm
simple track and hold (Read 489 times)
medya
Jul 18th, 2012, 2:55pm
hello,
i simulate this circuit in spectre with input freq=100k and sampling frequency of 100Msps ,taking fft from the output of switch(vi1-vi2) shows that the resolution is good but when change the input freq to 10M the output have low rwsulotion i reduce the rc time of circuit(switch close res=1mohm c=10f) but the result dont chnge what is the problem? Huh
thanks
Medya.
Re: simple track and hold
Reply #1 - Jul 19th, 2012, 6:22am
What does your tran analysis statement look like?  Some simulators set the timestep based on a fraction of the full transient time, so if you didn't make the full transient shorter when you increased the frequency, you wouldn't get small enough time steps.
