Aug 4th, 2024, 7:14pm
Comparator resolution 1.5bit/stage pipelined ADC (Read 1931 times)
medya
Aug 02nd, 2012, 3:30am
Assume that we design a pipelined ADC with 12bit resolution ,1.5bit/stage and vref=+/-1v,how the resolution of the comparators should be set?(in first stage), assume that the offset voltage is zero.
BackerShu
Re: Comparator resolution 1.5bit/stage pipelined ADC
Reply #1 - Aug 2nd, 2012, 10:20pm
First of all, assume whose offset voltage to be 0, opamp or comparator?
As to the comparator spec., at least the followings have to be met:
1. Speed. Assume conventional sturcture, about 0.5*Ts for comparator to give correct results. Make sure comparator meets this requirement in Worst Case condition and leave some margin based on your power budget.
2. Offset. For conventional 1.5b/Stage, the maximum offset can be tolerated is +/- 0.25*Vref; Yet, we usually don't go to this extreme. 250mV offset is really big, even in CMOS.  100mV may be more paratical. Again, how much margin you can have depends on how much power can be taken by comparators.
medya
Reply #2 - Aug 3rd, 2012, 5:33am
thanks a lot BackerShu
Let me to ask my question in other form, assume we design a latched comparator, the settling time of the latch is ts=(cl/gm)*ln (vf/vin)(of course in simple form) my problem is that for truly operation if we have a few gain in preampilifier(the offset is zero!) for sizing of the latch by knowing the cl,vf,and ts we need to the vin value( this value set the minimum detectable signal by the latch ). what is this value for our design:1m,10m,100m????? Huh
in ohter words what is the resolution of the comparator  6bit,10 bit,12bit?????????????what is it Undecided???
tell me a number!
best regards,
Medya.
