Jul 16th, 2024, 6:45pm
Hacking BJT model file (Read 3025 times)
yvkrishna
Aug 11th, 2012, 4:17am
I wanted to explore the effects of BJT beta(current gain =ic/ib) on VBE nature w.r.t temp etc.
I planned to edit the existing model file for 'BF' (ideal forward beta) value to a large number like 100 and re-simulate.
does doing this make the new bjt model valid and practical  or does it have some dependency to any other model parameter?
yvkrishna
Re: Hacking BJT model file
Reply #1 - Aug 13th, 2012, 5:40am
Maks gave a nice answer to your other (related) question:
http://www.designers-guide.org/Forum/YaBB.pl?num=1344685021
So, beta is related to other model parameters (or, perhaps, other model parameters capture other aspects of the same underlying physics).
That said, you can probably change beta by a factor of 2 and still have a "reasonable" model.
