Jul 16th, 2024, 11:16pm
what is the current equation to be used for hand calculation in 65nm? (Read 3415 times)
elektra
Aug 13th, 2012, 1:19am
            I have to design CDR which operates at 5GBPS in 65nm UMC technology. What is the saturated current equation for hand calculations...Even if the answer lies 20% around the accurate value..its ok for me...
A Kumar R
India
Re: what is the current equation to be used for hand calculation in 65nm?
Reply #1 - Aug 14th, 2012, 5:41am
You can simulate a transistor and find out the correction factor. What i mean is that if your transistors are not obeying the quadratic equation of the saturated current then you can find out the approximate "power" using this method. May be ~1.3 will be the power in those technologies but i am not sure...correct me if am wrong..
Anil Reddy
raja.cedt
Reply #2 - Aug 14th, 2012, 8:21am
use this pap
Alpha-Power Law MOSFET Model and its
Applications to CMOS Inverter Delay and
Other Formulas
Reply #3 - Sep 19th, 2012, 7:42am
plot a set of bias curves for the transistors at a fixed geometry.
Use W/L scaling to get to the desired current.
Done.
carlgrace
Berkeley, CA
Reply #4 - Nov 9th, 2012, 10:02am
loose-electron wrote on Sep 19th, 2012, 7:42am:
Done.
Strongly agree with this.  A bunch of hand calculation with square-law models will be a waste of time.
I'd suggest you look into the gm/I design methodology.  It works really well with nanometer processes.
